Specifies whether to save the body of the HTTP response message to a file. Select this field to enable the HTTP Response Content File Path field and the If Text Response, Save it Using Encoding field.
Specifies where to save the HTTP response message body. Type the path of the local file on the host where the touchpoint is running.
Specifies the action to take if the response file exists. Available actions are to create a file or overwrite the content of the existing file.
The path of the file is listed in the HTTPResponseContentFilePath operator output variable.
This value can be:
Specify this encoding if you are expecting a text response. The content-type of the response is of the format:
text/XXXX
This encoding is used to write the response in the Response File.
If the response received is not of type text/XXXX, this field is ignored.
This value can be:
If this field is set to 0 or 1, then field User Specified Text Response Encoding is disabled.
Specify an encoding to use when writing the text response in the Response File.
Specifies whether to save the body of the HTTP response message to the HTTPResponseContent variable in the dataset of the operator. When saving is selected, the HTTP Response Dataset Field Size Limit field is enabled.
Specifies the maximum number of bytes (of the HTTP response message body) to save in the HTTPResponseContent dataset variable of the operator.
A numerical value.
4096 bytes (if left blank)
