Specifies whether to use an indexed value map for HTTP request headers.
Specifies the names of the HTTP headers in the Key column and the values of the HTTP headers in the Value column. Headers must be in US-ASCII format.
Use the buttons to add, remove, or reorder headers.
Note: The operator ignores any header where the Key is blank, that is, where no header name is specified.
Specifies the name of an indexed ValueMap that contains the HTTP header names and corresponding values. The indexed ValueMap must be of the same format as the one listed in the HTTP Headers field. The indexed value map must have both the Key and Value parameters.
