Create and define as many Resource objects as required in each orchestrator. The Resource operator performs resource operations in a process. The Resource operator uses the current versions of specified Resource objects. Any modifications made to the Resource object in its current state are immediately available to the Resource operator upon check-in.
A new resource appears.
Note: You can also create Resource objects dynamically using code.
