Previous Topic: Create a Resource ObjectNext Topic: Monitor and Edit Resources
Edit a Resource Object
Edit a Resource object to manage individual resources within it. You can also manage versions, view properties, and examine the object's history.
Add individual resource entries for applications, connections, or other instances you want to control. This enables you to:
  1. Click the Library tab.
  2. Double-click a Resource object.
    The Resources dialog appears. The Resources tab opens by default.
  3. Click Add to add an individual resource.
  4. Review any of the values in the columns of the Resources tab. Click in the editable cells to enter new values.
    Name
    Lists the names of individual resources in a Resource object.
    Amount
    Lists the total number of units assigned to a resource. A unit is an arbitrary number that serves as a quota in a process.
    Used
    Indicates the number of assigned units.
    Free
    Indicates the number of unassigned units. Defined by the formula:
    Free = Amount - Used
    State
    Specifies whether a resource is locked or unlocked. Click the lock icon in this column to toggle the locked or unlocked state for a resource. You can also use a Resource operator to lock a resource programmatically in a schedule or process. Other Manage Resource operators cannot lock, unlock, take, or return resource units for a locked resource until the lock is released. A lock allows a process or schedule to monopolize a resource while it processes operators.
    % Usage
    Position your mouse over this visual indicator to view the numeric percentage of the resource currently being utilized. Any remaining portion is free.
    Description
    Provides a description of the resource. The Description column allows you to enter text that describes a resource.
  5. Click Check In or Save and Close.
Notes:
