When an SNMP trap triggers a process instance, you can monitor the SNMP process dataset with Process Watch. Use the following field descriptions to interpret the displayed values.
IP address of the source.
IP address of the SNMP agent, if available in the trap.
Version of the SNMP trap.
Error Index of the trap.
Uptime of the agent sending the trap.
Object identifier (OID) of the managed object that generated the SNMP trap.
Object IDs present in the payload of the trap. The payload object IDs represent a CA Process Automation string array variable.
Values in the payload that correspond to the values in PayloadOIDs. This data is also a CA Process Automation string array variable.
Note: If there are several filters, the first match is processed.
