Release Objects to Another Environment › Exporting and Importing › Baseline the Release Version of the Objects › Perform an Export › Export a Folder
Export a Folder
- Click the Library tab.
- Click Orchestrator, then select the appropriate Orchestrator:environment.
- Navigate to the object or folder to export, right-click the folder, and then select one of the following options:
- Export
Exports a folder or package in a modifiable mode.
- Export As Content Package (folders only)
Exports a folder as a content package in a nonmodifiable mode.
- To specify the export paths, select one of the following options:
- Export, Absolute Paths
Includes the full path for the selected folder.
- Export, Relative Paths
Includes the path relative to the folder that contains the selected folder.
Important! If the release version of the content package or its child objects is not set in the folder, the product aborts the export task.
- To save the XML file, click Save on the File Download dialog.
The default file name is folder-name.xml.
- Navigate to the location on your local drive at which to save the XML file.
Define the name with which to save the file. For example, append _RP to the file name to denote a relative path or _AP to denote an absolute path.
folder-name_RP.xml
folder-name_AP.xml
- Click Save.
CA Process Automation exports the folder and its contents.
More Information
Export Relative Paths or Export Absolute Paths
