To move the following items from the Library on one Orchestrator to the Library on another Orchestrator, use the export and import processes:
For example, you can copy from a development environment to a production environment or copy from one Orchestrator to another Orchestrator in the same environment. The export process creates an XML file that the import process uses. After you export objects, you import them on the destination Orchestrator.
Consider the following points before you export and import:
The following topics explain the export process.
CA Process Automation lets you export objects and folders in various ways. Every export option creates an XML file that you can import to a different environment.
You can export the following items:
You can only export an object in a modifiable mode. You can add a release version to the object, but it is not required. After you import an object to a new environment, you can modify the object directly.
Exporting a folder exports the folder and its contents, including any subfolders. The contents can include any object available in the CA Process Automation Library.
You can export a folder in a modifiable mode so that you can modify the folder and its contents directly in a new environment. The product does not require objects that you export through a folder to have a release version.
The product preserves the path to the folder and the hierarchical structure of objects and subordinate folders in the export file.
A folder becomes a content package upon export and you cannot modify it in the new environment. The product preserves the path to the folder and the hierarchical structure of objects and subordinate folders in the export file.
You can add release information to a folder to export as a content package. The release version attribute is required for all folders, but you can add other relevant information about the folder or the objects in it.
It is good practice to export a folder as a content package when you are transitioning a new process with its components from the design environment to the production environment. The recipients in the production environment cannot modify the contents of the content package.
Important! If you do not set the release version of the content package or the child objects in the folder, the product aborts the export task.
The package object is only supported for backward compatibility in CA Process Automation 04.2.00. You cannot reference packages in interaction request forms, start request forms, custom operators, process watches, or datasets. You can still export a 04.1.00 package, but you cannot modify the package after you import it to a new environment. You can, however, modify the package objects.
To bundle similar objects and export them to a new environment, use a content package instead.
Packages that you migrate from release 04.1.00 to release 04.2.00 export the same way as an object.
Note: You cannot export multiple folders or automation objects simultaneously. Instead, create a folder and then assemble all the objects to export as a single content package. You cannot export a folder that already contains a content package as a content package.
