To move objects, folders, packages, and content packages from the Library on one Orchestrator to the Library on another Orchestrator, use the export process. The Orchestrator can be on the same environment or a different environment.
Note: Packages that you migrate from release 04.1.00 to release 04.2.00 export in the same way as an object.
Includes the full path for the selected object.
Includes the path relative to the folder that contains the selected object.
The default file name is object-name.xml.
For example, append _RP to the file name to denote a relative path or _AP to denote an absolute path.
object-name_RP.xml
object-name_AP.xml
The product exports the object.
