Starts the REST service at a specified URL that requires authentication. The server calls the REST Methods asynchronously.
The onSuccess(result) or the onFailure(caught) function of the callback object runs as appropriate after the data is retrieved from the server. The result can be any data format that the REST service returns. The method supports only Basic HTTP authentication. You can use this method with the following signatures:
ca_pam_postRESTDataAuth(url, userName, password, callBack) ca_pam_postRESTDataAuth(url, userName, password, body, callBack) ca_pam_postRESTDataAuth(url, userName, password, body, contentType, callBack) ca_pam_postRESTDataAuth(url, userName, password, body, contentType, doNotValidateCert, callBack)
Defines the URL of the HTTP request. The URL starts with http:// or https://.
Defines the user name for which to authenticate the specified URL.
Defines the password that is associated with the specified user name.
Defines the data to send in the HTTP request.
Defines the type of content that comprises the HTTP request body. This value is sent as a header (content-type) in the HTTP request.
Specifies whether a valid SSL certificate is found. This field is relevant when querying an HTTPS URL.
Defines a list of key/value pairs that sets headers in the request.
Defines a reference to the function object to call after retrieving the data, including its onSuccess and onFailure methods.
When the function retrieves the data, either the onSuccess(result) or onFailure(caught) callBack function runs. The function itself does not return any value.
You can find this function in the out-of-the-box content in CA Process Automation.
