Previous Topic: ca_pam_getRESTDataAuth(url, userName, password, doNotValidateCert, headers, callBack)Next Topic: ca_pam_postRESTDataAuth(url, userName, password, body, contentType, doNotValidateCert, headers, callBack)
ca_pam_postRESTData(url, body, contentType, doNotValidateCert, headers, callBack)
Uses the HTTP post method to start the REST service. You can use this method with the following signatures:
ca_pam_postRESTData (url, callBack)
ca_pam_postRESTData (url, body, callBack)
ca_pam_postRESTData (url, body, contentType, callBack)
ca_pam_postRESTData (url, body, contentType, doNotValidateCert, callBack)
Input Parameters
url (string)
Defines the URL of the HTTP request. The URL starts with http:// or https://.
body (string)
Defines the data to send in the HTTP request.
contentType (string)
Defines the type of content that comprises the HTTP request body. This value is sent as a header (content-type) in the HTTP request.
doNotValidateCert (boolean)
Specifies whether a valid SSL certificate is found. This field is relevant when querying an HTTPS URL.
  • false - Validates the SSL certificate and fails the operation if the certificate is invalid.
  • true - Accepts the SSL certificate even if it is invalid and continues to make the HTTP call.
headers (object)
Defines a list of key/value pairs that sets headers in the request.
callBack (object)
Defines a reference to the function object to call after retrieving the data, including its onSuccess and onFailure methods.
Return Value
When the function retrieves the data, either the onSuccess(result) or onFailure(caught) callBack function runs. The function itself does not return any value.
