Previous Topic: Edit a Resource ObjectNext Topic: Add a Manage Resources Operator to a Process
Monitor and Edit Resources
You can monitor and edit the resources in a Resource object on the Operations page. The Operations page allows you to modify the current version of a Resource object. Your changes are automatically applied to any Manage Resource operators using the Resource object.
  1. Click the Operations tab.
  2. In the Links pane:
    1. Expand Process Watch or Resources.
    2. Expand the list of folders or search for a specific process watch or resource object.
    3. Select a resource object.
      The current version of the Resource object appears.
  3. Select a resource and then make any of the following changes.
    1. In the toolbar, click Lock to lock the resource. Click Unlock to unlock a resource. You can also click the lock icon in the State column to toggle this setting.
    2. Click Clear to release any used resources and reset free resources to the maximum amount available.
    3. Click the Amount, Used, and Description fields to edit their values.
    4. Click Refresh to view the latest system data.
      Your changes are available to Manage Resource operators.
  4. To add or edit resources in a Manage Resource operator in a Schedule:
    1. Expand Links and click Active or Global Schedules.
    2. In the list of schedules, double-click a schedule.
    3. In a Manage Resources item of the schedule, click Properties.
    4. Click the Specific tab.
    5. Click Check Out.
    6. Click Add, Edit, or Delete to configure the resources.
    7. Click Check In or click Save and Close.
