The general structure of a CA Process Automation process consists of two basic items: operators and links. Operators perform tasks or conditional tests. Links connect operators and determine the processing sequence.
The following list describes some examples of operators:
Links connect operators and carry out the processing flow. The point where an operator and link intersect is called a port. A link originates at the exit port for one operator and ends at the entry port for another operator.
When a process between two operators runs, the processing sequence can be summarized as follows:
An operator can have multiple exit ports to handle various results. Each exit link can initiate a separate branch of operators in a subprocess or child process. Exit and entry ports enforce a linear sequence in which operators are processed. They can direct the process flow to a particular branch of a process depending on the outcome of a single operator.
To direct processing based on the outcomes of multiple operators, use the following operators:
These operators allow you to design multiple entry and exit branches for other operators. You can also create links that depend on the outcomes of multiple operators.
