Use the Library Browser to create a Process object in a folder. You can also create a process in the Designer and specify a folder when you save it. Create a Process object for every discrete automation sequence, flow, or subprocess that you want to automate. After creating the Process object, design the process by adding operators and connecting them with links.
Note: To set rights and perform other object tasks, the best practice is to organize the objects in folders. Do not create objects at the root level because you cannot manage such objects as a group.
A new process object appears with a default name. The process is automatically checked out to you to capture your exclusive changes.
You have created a new process object. Next, you can design the process.
