Operators and Icons › Operator Icons › Creating, Editing, and Applying Custom Icons › Apply a Custom Icon to Any Operator in a Process
You can change the icon for any single operator used in a process.
- Click the Designer tab.
- Click Open.
The Open Process dialog opens.
- Navigate to your process and click Open.
The process that you open appears on a new tab.
- Double-click a specific operator already shown on the canvas to view its Properties. In the toolbar, click the View menu and check Properties to view the Properties palette.
- In the Properties palette, expand the Information section.
- In the Information section:
- Clear the Use default Icon check box.
A border appears around the current icon and a Browse button is available.
- Click the Browse button.
The Select Custom Icon dialog appears.
- Select the custom icon object that you want to use for this specific occurrence of the operator.
- Click OK.
- In the toolbar, click Save.
Note: You cannot change the icons that are associated with the execution state of an operator. For example, waiting or completed. CA Process Automation automatically manages these icons.
