You can change the icon for a custom operator. The icon that you select applies to all future occurrences of the custom operator in processes. Existing occurrences of the custom operator in processes continue to show the original default icon for the base operator.
A hierarchical list of folders appears in the left pane and all your automation objects are listed in the main window by type.
The Custom Operator window appears.
Note: You cannot change the icons that are associated with the execution state of a custom operator. For example, waiting or completed. CA Process Automation automatically manages these icons.
