Over time, the custom icons you and other designers create can be modified to align with other icons. You can edit custom icons in any automation library folder. Each icon pairs your choice of base image with a modifier image overlaid in the lower-right corner of the base. The base and modifier provide a consistent structure for all icons.
A hierarchical list of folders appears in the left pane and all your automation objects appear in the main window.
The Custom Icon Editor opens.
Your modifications to the custom icon are applied.
For example, if you want to represent an operator named Upload Report, you would:
