Operators and Icons › Operators › Custom Operators › Custom Operator Properties › Custom Operator: Settings Tab › Custom Operator-Specific Pre-execution and Post-execution Code › Run Order for Custom Operator-specific Pre-Execution Code
The run order for the custom operator-specific pre-execution code is as follows:
- Run the user-defined pre-execution code (that is, the pre-execution code defined in the process).
- Evaluate the User Parameters (this step includes evaluating expressions and expanding macros).
- Run the custom defined pre-execution code. The User Parameters are exposed and you can use the Operator keyword to access the parameters.
Note: The designer does not have the permissions to change User Parameter values.
- Evaluate the Standard Parameters (this step includes evaluating expressions and expanding macros).
- Evaluate the Base operator.
