To define and group operator dataset variables that contain information that a custom operator returns, use the Dataset tab.
For example, assume that your custom operator retrieves fields from a ticket in an in-house ticketing system. You can create a page to group all the retrieved fields and put the parameters in the page that corresponds to the returned fields.
Using the Dataset tab in this way provides the following benefits:
In the Dataset palette, you can add, rename, delete, and move pages and parameters. You can also configure the parameter definitions to set the type, initial value, and other characteristics. The configurations and settings in the Dataset palette of a custom operator are the same as for any other dataset.
For each output parameter name/value pair on the left, you can configure whether to hide the parameter value from output.
Specifies whether to include the parameter with the output.
