Operators and Icons › Operators › Custom Operators › Custom Operator Properties › Custom Operator: Settings Tab › Custom Operator-Specific Pre-execution and Post-execution Code › Define Custom Operator-specific Pre and Post Execution Code
To prevent accidental deletion or modification of execution code, you can define specific code for each custom operator. You can also use the custom operator input or output data in your code.
- Click the Library tab.
- Double-click a custom operator.
The Custom Operator dialog appears.
- Click the Settings tab.
- Click one of the following two long buttons:
- Click Custom Operator Pre-execution to enter pre-execution code.
- Click Custom Operator Post-execution to enter post-execution code.
A code dialog appears.
- Enter your code. Click OK.
- Click Save.
