Administer Library Objects › Create and Manage Folders › How to Manage Folders › Move a Folder
Move a Folder
You can move folders in an Orchestrator library.
Note: To move a folder from one Orchestrator library to another, export the folder.
- Click the Library tab.
- Click Orchestrator and select the Orchestrator:environment with the library that contains the source folder.
- Navigate the folder tree, expanding folders as needed.
Note: Enter the partial folder name to display folders with names that begin with the string you entered.
- When the target folder is displayed, select it and click Cut.
- Navigate to the destination folder, then click Paste.
One of the following results occurs:
- If the destination folder name differs from the source folder name, the Orchestrator adds the source folder as a subfolder of the destination folder.
- If the destination and source folders have the same name, the Orchestrator adds the source folder contents to the destination folder. That is, the Orchestrator merges the contents of the two folders.
