When you export one of the following items, the product creates an XML file that you can import:
Note: For more information, see Scenario: Prepare a Folder for Export as a Content Package.
Content administrators and content designers can export a folder from the Library Browser to an export file on the local host. The export file preserves the path to the folder and the hierarchical structure of objects and subordinate folders.
Administrators can export a folder in the following ways:
The modifiable export lets the recipients in the target environment update the exported object versions in the folder.
The nonmodifiable export does not let the recipients in the target environment update the exported object versions or the Release Version label.
Note: You cannot export objects that reside in multiple folders as shortcuts in a package. Instead, create an export folder and then assemble all of the objects for export in that folder. For more information, see the Content Designer Guide.
Note: The default file name is folder-name.xml.
For example, append _RP to the file name to denote a relative path or _AP to denote an absolute path.
folder-name_RP.xml
folder-name_AP.xml
The product exports the folder and its contents.
