Administer Library Objects › Create and Manage Folders › How to Manage Folders › Show the Contents of a Folder
Select a folder to display its contents.
- Click the Library tab.
- Click Orchestrator and select the appropriate Orchestrator:environment.
- Navigate the folder tree, expanding folders as needed. Or, enter search criteria in the search field to filter the displayed list to folders beginning with the name you entered.
- When the target folder is displayed, select it.
The folder contents are displayed in table format on the main pane.
- (Optional) Display the data in the desired order. Click the header of the column on which you want to sort and select Ascending or Descending.
