Administer Orchestrators › Configure the Contents of an Orchestrator Host › Override Operator Category Settings Inherited from Environment
Operator category settings are configured on the Modules tab. Operator category settings that have been configured at the Environment level or inherited from settings configured at the Domain level are displayed as Inherit from Environment. An administrator with Environment Configuration Administrator rights can enable any operator category and override inherited settings at the Orchestrator level.
- Click the Configuration tab.
- Expand the Orchestrators palette.
- Select the Orchestrator you want to configure, and click Lock.
- Click the Modules tab.
- Select an operator category, click Inherit from Environment, and select Enable from the drop-down list.
Note: You can disable an operator category at the Orchestrator level by selecting Disabled from the drop-down list.
- Right-click the operator category and select Edit.
The settings are displayed.
- Change one or more inherited settings.
Note: See Configuring Operator Categories for details.
- Click Save and Close.
The values configured in the open dialog are saved.
- Click the Save toolbar button.
The saved changes are applied to the CA Process Automation configuration.
- Repeat Steps 5-9 for each operator category to update.
- Select the Orchestrator you configured, and click Unlock.
More information:
Configure Network Utilities
Configure Web Services
Configure Process Control
Configure File Management
Configure Command Execution: Default Telnet Properties
