Administer Orchestrators › Configure the Contents of an Orchestrator Touchpoint
To configure an Orchestrator touchpoint, select that Orchestrator under an Environment node. All but one of the settings is view-only.
To configure settings that pertain to the Orchestrator host, select the Orchestrator under the Orchestrators node.
Note: For configuration details see, Configure the Contents of an Orchestrator Host.
The tabs for Contents of the selected Orchestrator follow:
The only configurable field on this set of tabs is that for Touchpoint Security. On the Properties tab, set Touchpoint Security to True only after you have configured a Touchpoint Security policy.
Topics for the Orchestrator tabs follow:
- Security - Security settings do not apply to the Orchestrator Touchpoint. The fields are read-only from the Orchestrator touchpoint view.
- Properties - You can configure Orchestrator touchpoint properties.
- Modules - Operator categories are not configurable from an Orchestrator touchpoint. You can edit settings by selecting the Orchestrator host.
- Triggers - Triggers are not configurable from an Orchestrator touchpoint. You can edit settings by selecting the Orchestrator host.
- Policies - Policies are not configurable from an Orchestrator touchpoint. You can edit settings by selecting the Orchestrator host.
- Mirroring - Mirroring is not configurable from an Orchestrator touchpoint. You can edit the mirroring setting by selecting the corresponding Orchestrator host.
- Audit Trails - Audit trail actions do not apply to Orchestrator touchpoints. You can view audited actions on the corresponding Orchestrator host.
