Administer Orchestrators › Configure the Contents of an Orchestrator Touchpoint › Configure Orchestrator Touchpoint Properties
The Orchestrator touchpoint Properties pane provides information about the touchpoint that is associated with the Orchestrator. You can view status information and you can change the configuration of Touchpoint Security for this Orchestrator touchpoint.
- Click the Configuration tab.
- Expand the Domain and the environment with the Orchestrator touchpoint.
- Select the Orchestrator touchpoint to configure and click Lock.
- Click the Properties tab.
- (Optional) Configure the Touchpoint Security setting. Specify whether to inherit the setting or set the value at the Orchestrator level. When enabled, processes use the Touchpoint Security policies to authorize users to execute operators in a process.
- Configure the default settings for how operators process an IP address or host name in the Target field or when referenced by a dataset.
- The Match target in Host Groups only? drop-down list selection specifies the search scope for an operator target when the Target field entry is an IP address or a host name (FQDN). The operator execution on the target can proceed only when the target is known to CA Process Automation.
- Select Disabled to allow the broadest search.
- Select Enabled here and Disabled for the next field for the most restricted search.
- When the Lookup DNS when matching target in Host Groups? drop-down list is enabled, specify whether to limit the search through Host Group references to the entry type.
- Select Enabled to search all host group references.
- Select Disabled to restrict the search to host group references that include an exact match to the Target field entry.
- Click Save.
- Select the Orchestrator and click Unlock.
- View the informational properties. For more information, see the tooltips.
