When you delete an object or folder from the library, it moves to the Recycle Bin. From the Recycle Bin, you can restore an object or folder that you deleted. The restore process restores the object or folder and any other folders in the deleted path. You can specify whether to overwrite objects in the target path that have the same name as selected objects.
The main grid refreshes to display all automation objects and folders that currently reside in the Recycle Bin.
The product moves the object from the Recycle Bin to the target path and overwrites the object that exists in the target path.
The product does not overwrite the object in the target path. In this case, consider moving or renaming the object with the duplicate name and then retrying the restore process.
The restore process restores the selected objects and, if necessary, their folder paths.
