Administer Library Objects › Use the Recycle Bin › Search the Recycle Bin
You can query the Recycle Bin with a basic search or an advanced search. The basic search filters on the name when the entry is the whole name or a string that begins like certain names. The Advanced Search provides many search criteria.
- Click the Library tab, contract the root folder, and select the Recycle Bin.
All currently deleted automation objects and folders appear in the main pane.
- Enter a string and an asterisk (*) in the search field and click Search to perform a basic search. For example, enter Custom* to limit the display to objects beginning with the string Custom.
Folders and automation objects with names matching your entry appear in the filtered list.
- Click Advanced Search to display attributes on which to search. You can enter one or more types of search criteria.
- Keywords - Enter one or more keywords to find objects or folders that are assigned the specified keywords. If you specify more than one keyword, use the comma (,) as a delimiter.
- To filter for objects that are tagged with any of the keywords you specify, select OR, the default.
- To filter for objects that are tagged with all the keywords you specify, select AND.
- Name - Name of the folder or automation object.
- Owner - User ID of the object or folder owner. The default owner is the user who created the object. A new owner can be specified with Set Owner.
- Type - Select an automation object type from the drop-down list.
- State - Select a state from the drop-down list.
- Modification Date - Use the calendars to select the date range during which the items you want displayed were modified.
- Creation Date - Use the calendars to select the date range during which the items you want displayed were created.
- Click Search.
- Take the purge or restore action on the result set.
- Click Reset to clear the search criteria if you want to do another search right away.
