Administer Library Objects › Use the Recycle Bin › Purge Objects and Folders
The Recycle Bin is intended to be a temporary container for deleted objects, such that content designers can restore objects that they inadvertently delete.
Purging obsolete objects regularly results in a tidy Recycle Bin. As an administrator, you can purge selected automation objects and folders. Alternatively, you can purge the contents of the Recycle Bin in a single step. A purged object cannot be retrieved or restored.
- Click the Library tab.
- Click Orchestrator and select the appropriate Orchestrator:environment.
- If the Recycle Bin is not visible, contract the root folder.
- Click the Recycle Bin.
All automation objects and folders that are deleted from the library appear in the main pane grid.
- Take one of the following actions:
- Select specific objects, and then click Purge selected.
- Click Purge all.
- If you initiated the purge for selected objects, a confirmation message appears.
- Click No to cancel the purge, restore the required objects to the Library, restart the purge.
- Click Yes to continue with the purge process.
- If you initiated a purge all process where the contents of the recycle bin include checked out objects, a dialog appears that lists these objects. Evaluate the list and then take one of the following actions:
