Use a content package to export and import a set of related objects that compose a release version from one Orchestrator to another Orchestrator. In most cases, the source and target Orchestrators are in different environments. When you export a folder as a content package, the export process creates an XML file on your local drive. When you import into a different Orchestrator, you select this XML file from your local drive. The imported result is the content package.
