Configure the properties for a selected environment from the Configuration tab. Environment Configuration Administrator rights are required to configure environment properties or override settings at a level that can inherit from the environment.
Specifies whether to automate recovery. Recovery applies to specific operators that fail with a SYSTEM_ERROR and have recoverable processes that are in a BLOCKED, RUNNING, or WAITING state. Select True to begin recovery when the inactive Orchestrator or agent becomes active. Recovery resets operators that were in SYSTEM_ERROR and resumes their processes. The reset operators in a resumed process begin running on the associated targets. The Operator targets can be Orchestrators, touchpoints, hosts that are connected to proxy touchpoints, or hosts in a host group.
Values: This property has the following values:
Default: Selected.
Specifies whether to inherit the value that is configured in the Domain properties or to set the value at the environment level.
Default: Inherit from Domain.
Specifies the search scope for an operator target when the Target field entry is an IP address or a host name (FQDN). The operator execution on the target can proceed only when the target is known to CA Process Automation. Select Disabled to allow the broadest search. Select Enabled here and Disabled for the next field for the most restricted search.
Note: A DNS lookup of a specified hostname finds associated IP addresses; a DNS lookup of the IP address finds associated hostnames.
If a DNS lookup is disabled, searches: Host group reference to a remote host (exact)
If a DNS lookup is enabled, searches: Host group reference to a remote host (exact or DNS lookup result)
Touchpoint (exact or a DNS lookup result)
Orchestrator (exact or a DNS lookup result)
Agent (exact or a DNS lookup result)
Proxy touchpoint mapping to a remote host (exact or DNS lookup result)
Note: This field is enabled when the "Match target in Host Groups only" is set to Enabled.
Specifies whether to limit the search through Host Group references to the entry type. For example: When the Target field entry type is an FQDN, search only host name patterns. When the Target field entry type is an IP address, search only subnets. When a DNS lookup is included, the search can also accept a host group reference to the other type, as resolved by a DNS lookup.
The environment property updates are active.
