After you install software using CA MSM, you still need to deploy it. You can use the deployment wizard to guide you through the deployment process. In the wizard, you can deploy one product at a time. You can also save a deployment at any step in the wizard, and then manually edit and deploy later.
Note: You must have at least one product, one system, and one methodology defined and selected to deploy.
You must complete the following steps in the Deployment wizard before you deploy:
Enter the deployment name and description using the wizard. The name must be a meaningful deployment name.
Note: Each deployment name must be unique. Deployment names are not case-sensitive. For example DEPL1 and depl1 are the same deployment name.
We recommend that you enter an accurate and brief description of this deployment.
Select a CSI. A CSI is created for the installed product as part of the installation process.
Displays the products that are installed in the CSI you selected.
Custom data sets let you add other data sets along with the deployment. They contain either a z/OS data set or USS paths.
You can add a custom data set.
Methodology is the process by which data sets are named on the target system. A methodology provides the how of a deployment, that is, what you want to call your data sets. It is the named objects with a description that are assigned to an individual deployment.
To create a methodology, specify the following:
Lets you choose symbolic variables that get resolved during deployment.
If you select Create, ensure that the target data sets do not exist, otherwise, the deployment fails.
If you select Create or Replace and the target data sets do not exist, they will be created. If the target data sets exist, Create or Replace indicates that data in the existing data set, file, or directory will be replaced, as follows:
Create or Replace indicates that existing members in a partitioned data set will be replaced by members with the same name from the source file. Any currently existing member that is not in the source file will remain in the PDS. Any member from the source that does not already exist in the target PDS will be added to the target PDS.
The amount of free space in the PDS should be sufficient to hold the additional content, because no automatic compress is performed.
Create or Replace indicates files in a directory will be replaced by files with same name from the source. Any currently existing directory in a UNIX file system that is not in the source will remain in the UNIX file system.
Create or Replace indicates the existing data set or file and its attributes will be replaced with the data from the source file.
Create or Replace indicates that an existing VSAM cluster should be populated with the data from the source file. The existing VSAM cluster must be of the same type as the source cluster (ESDS, KSDS, LDS, or RRDS). In addition, the existing VSAM cluster must have characteristics that are compatible with the source cluster (such as, record size, key size, and key offset). Replace does not verify the compatibility of these characteristics!
Note: You can replace the contents of an existing cluster using the IDCAMS ALTER command to alter the cluster to a reusable state. You must do this before the data from the VSAM source is copied into the cluster using an IDCAMS REPRO command. The REPRO command will use both the REPLACE and REUSE operands, and after you use it, the cluster is altered back to a non-reusable state if that was its state to begin with.
Select the system for this deployment.
Preview identifies the deployment by name and briefly states the products, systems, means of transport, target libraries including source, target and resolution, as well as SMP/E environment and snapshot information. It shows the translated symbolic qualifiers.
Use this option to review your deployment before deploying.
Deploy combines the snapshot, transmit, and deploy action into one action. Deploy enables you to copy your CA MSM-installed software onto systems across your enterprise. For example, you can send one or many products to one or many systems. Deploy can send the software by copying it to a shared DASD or through FTP.
After your products have successfully deployed, you can review your deployment summary and then confirm your deployment. You can also delete a completed deployment.
Confirms that the deployment is complete. A deployment is not completed until it is confirmed. After it is confirmed, the deployment moves to the Confirmed deployment list.
Copyright © 2012 CA.
