Installing Your Product Using CA MSM › Getting Started Using CA MSM › How to Use CA MSM: Scenarios
In the scenarios that follow, imagine that your organization recently deployed CA MSM to simplify the installation of CA Technologies products and unify their management. You have also licensed a new CA Technologies product. In addition, you have a number of existing CSIs from previously installed products.
- The first scenario shows how you can use CA MSM to acquire the product.
- The second scenario shows how you can use CA MSM to install the product.
- The third scenario shows how you can use CA MSM to maintain products already installed in your environment.
- The fourth scenario shows how you can use CA MSM to deploy the product to your target systems.
Copyright © 2012 CA.
