You must add and then validate each system in the enterprise that you are deploying to the CA MSM system registry. You can only send a deployment to a validated system. This process is called registering your system and applies to each system in your enterprise. For example, if you have five systems at your enterprise, you must perform this procedure five times.
Note: After a system is registered, you do not need to register it again, but you can update the data in the different registration fields and re-register your system.
The system registration process contains the following high-level steps:
This is where you provide a user ID and password to the remote target system where the deployment will copy the installed software to. Remote credentials are validated during the deployment process. You will need the following information:
Your system administrator can help you with setting up your remote credentials.
The CA MSM system registry is a CA MSM database, where CA MSM records information about your systems that you want to participate in the deployment process. There is one entry for each system that you register. Each entry consists of three categories of information: general, FTP locations, and data destinations.
Each system registry entry is one of four different system types. Two reflect real systems, and two are CA MSM-defined constructs used to facilitate the deployment process. The two real system types are Non-Sysplex System and Sysplex Systems. The two CA MSM-defined system types are Shared DASD Clusters and Staging Systems.
Specifies a stand-alone z/OS system that is not part of a sysplex system.
Note: During system validation, if it is found to be part of a sysplex, you will be notified and then given the opportunity to have that system automatically be added to the sysplex that it is a member of. This may cause the creation of a new sysplex system. If you do not select the automatic movement to the proper sysplex, this system will be validated and cannot be deployed.
Specifies a Sysplex (SYStem comPLEX), which is the IBM mainframe system complex that is a single logic system running on one or more physical systems. Each of the physical systems that make up a Sysplex is often referred to as a member system.
A Monoplex system is a sysplex system with only one system assigned.
Note: Monoplexes are stored in the Sysplex registry tree but with the name of the Monoplex System and not the Monoplex Sysplex name. For example, a system XX16 defined as a Monoplex, with a Sysplex name of LOCAL. It will be depicted in the System Registry as a Sysplex with the name of XX16. This sysplex will contain one system: XX16.
This system type can help you if you have Monoplexes with the same Sysplex name (for example: LOCAL). Instead of showing multiple LOCAL Sysplex entries that would need to be expanded to select the correct Monoplex system, the CA MSM System Registry shows the actual Monoplex System name at the top-level Sysplex Name.
Specifies a Shared DASD Clusters system, which defines a set of systems that share DASD and it can be composed of Sysplex systems, Non-Sysplex systems, or both. A Staging system cannot be part of a Shared DASD Cluster.
Specifies a Staging system, which is an SDS term that defines a virtual system. A Staging system deploys the deployment to the computer where the CA MSM driving system is located. To use a Staging system, the CA MSM driving system must be registered in the CA MSM System Registry.
Note: A Staging system can be useful in testing your deployments and learning deployment in general. It can also be used if your target systems are outside a firewall. For example, deploy to a Staging system and then manually copy the deployment to tape.
FTP locations are used to retrieve the results of the deployment on the target system (regardless if the deployment was transmitted through FTP or using Shared DASD). They are also used if you are moving your deployments through FTP.
To define the FTP location, provide the following:
Specifies the host system name.
Specifies the port number.
Default: 21.
Specifies the landing directory, which is the location that the data is temporarily placed in during a deployment.
The data destination is how you tell CA MSM which technique to use to transport the deployment data to the remote system. The following choices are available:
When FTP is selected as the transport mechanism, the deployment data is shipped to the target system through FTP. It is temporarily placed on the target system at the landing directory specified in the FTP Location information section of the System Registry.
When you specify shared DASD, CA MSM uses a virtual transport technique. That is, it does not actually copy the data from one system to the other. Because the two systems share DASD, there is no need to do this. All of the deployment data is kept in USS file systems managed by CA MSM.
Even though the DASD is shared, the remote system may not be able to find the deployment data in the USS file system. Therefore, CA MSM temporarily unmounts the file system from the CA MSM driving system and mounts it in read-only mode on the remote system.
For CA MSM to determine where to mount the file system on the remote system, you must specify a mount point location in the data destination. In addition, you can provide allocation information for the creation of the deployment file system, so that when the file system is created on the CA MSM driving system, it will be on the DASD that is shared.
Data destinations are assigned to Non-Sysplex and Sysplex systems, and Shared DASD Clusters. Data destinations are named objects, and may be assigned to multiple entities in the system registry and have their own independent maintenance dialogs.
The remote allocation information is used by the deployment process on the remote system, letting you control where the deployed software is placed. By specifying the GIMUNZIP volser, CA MSM adds a volume= parameter to the GIMUNZIP instructions on the remote system. The list of zFS VOLSERs is needed only if both of the following occur:
Note: After you have created your systems, you will need to validate them.
Note: You should validate your Non-Sysplex Systems first, and then your Sysplex or Shared Cluster Systems.
You start the validation process when you select the Validate button in the Actions drop-down list for a Sysplex System, Non-Sysplex System, and Shared DASD Cluster on that system's System Registry Page. This starts a background process using the CCI validation services to validate this system.
Note: Staging Systems are not validated. However, you will need to create and validate a system registry entry for the CA MSM driving system if you are going to utilize Staging systems.
Note: If the validation is in error, review the message log, update your system registry-entered information, and validate again.
You are now ready to deploy your products.
Copyright © 2012 CA.
