Previous Topic: Compatibility with CA MIMNext Topic: Compatibility with CA PDSMAN and eTrust CA Top Secret
Compatibility with CA PDSMAN and CA Panexec
If you operate CA PMOwith both CA PDSMAN and CA Panexec, do not specify PANEXEC=YES in your parameter data set. If you do, CA PMO continually stops and restarts itself, exhausting ECSA in the process. This happens because CA PMO does not reuse its ECSA when it automatically stops and restarts itself.
When using CA PMO>, CA PDSMAN, and CA Panexec, be sure that you start up CA Panexec before starting CA PMO and CA PDSMAN. The order in which CA PMO and CA PDSMAN are started is irrelevant. Unless you use CA PDSMAN, you must contact CA Technical Support. for any PTFs.
