Previous Topic: Resetting the Candidate ListNext Topic: Resuming Update Detection
Resetting Peak Interval Statistics
One of the D5 monitor displays shows statistics on performance and cost savings during the peak interval (the interval of CA PMO activity with the most library directory searches). You use the F PMO,RESETPK command to instruct CA PMO to reset the peak interval statistics and begin gathering new peak interval statistics.
Format
The RESETPK command has the following syntax:
F PMO,RESETPK
This command has the following operands:
PMO
The CA PMO keyword.
RESETPK
Causes CA PMO to reset the peak interval and gather new peak interval statistics.
Messages
After resetting the peak interval statistics, CA PMO responds:
PMO312I PEAK INTERVAL STATISTICS RESET. PEAK INTERVAL SET TO CURRENT INTERVAL
Note: The F PMO,RESET command resets all of CA PMO statistics, and the RESETPK parameter automatically resets the peak interval statistics at midnight.
