Previous Topic: Resetting All StatisticsNext Topic: Resetting Peak Interval Statistics
Resetting the Candidate List
The D9 display lists private libraries that are good candidates for CA PMO management. To cause CA PMO to clear and rebuild the candidate list, issue the RESETCND command.
Format
The RESETCND command has the following syntax:
F PMO,RESETCND
This command has the following operands:
PMO
The CA PMO keyword.
RESETCND
Causes CA PMO to remove all candidates from the candidate list. CA PMO starts to rebuild the candidate list after executing this command.
Messages
After resetting the candidate list, CA PMO responds:
PMO314I CANDIDATE LIST RESET
Note: You can use the F PMO,RESET command to reset all of CA PMO statistics in addition to resetting the candidate list.
