Previous Topic: Resetting Peak Interval StatisticsNext Topic: Writing Report Output to a Data Set
Resuming Update Detection
The RESUREF command resumes detection of updates to a private or LNKLST library managed by CA PMO.
Format
The RESUREF command has the following syntax:
F PMO {,RESUREF=data set name} [,VOL=volser]
      {,RESUREF=LNKLST}
This command has the following operands:
PMO
The CA PMO keyword.
RESUREF
You specify this operand as follows:
Tells CA PMO to resume detection of updates for data set name. If data set name is a LNKLST library, CA PMO clears the managed list and refreshes LLA. If data set name is a private library, CA PMO rebuilds the library hash table.
RESUREF=LNKLST
Tells CA PMO to resume detection of updates for all LNKLST libraries. The managed list is cleared and LLA is refreshed.
VOL=volser
The volume serial number of the volume on which the data set resides. You must use this option if CA PMO is managing multiple libraries with the same name.
