Previous Topic: Displaying Volumes That Are Offline to CA PMONext Topic: Making Volumes Eligible for Management
Removing Volumes from Management
The OFFLINE command removes entire volumes from CA PMO management. Before you take a volume in your data center offline, you should issue this command so that CA PMO does not manage libraries on the specified volume.
Format
The OFFLINE command has the following syntax:
F PMO {,OFFLINE=ALL}
      {,OFFLINE=volser name}
      {,OFFLINE=volser list}
This command has the following operands:
PMO
The CA PMO started task name.
OFFLINE
Specify this operand like this:
OFFLINE=ALL
Excludes all volumes from CA PMO management.
OFFLINE=volser name
Excludes the specified volume from CA PMO management.
OFFLINE=(volser list)
Excludes the specified list of volumes from CA PMO> management. Enclose the list in parentheses and separate each volser name with a comma. A maximum of four volumes can be specified.
Examples
F PMO,OFFLINE=ALL
F PMO,OFFLINE=USRVOL
F PMO,OFFLINE=(MYVOL1,MYVOL2,MYVOL3)
Note:
Keep the following items in mind when using the OFFLINE command:
