Previous Topic: Refreshing the Directory Entry for a LNKLST MemberNext Topic: Removing Volumes from Management
Displaying Volumes That Are Offline to CA PMO
The OFFCHECK command determines which volumes you have excluded from CA PMO management with the F PMO,OFFLINE command.
Format
The OFFCHECK command has the following syntax:
F PMO,OFFCHECK
This command has the following operands:
PMO
The CA PMO keyword.
OFFCHECK
InMessages
CA PMO responds to the F PMO,OFFCHECK command with one of the following messages:
PMO361I ALL VOLUMES CURRENTLY OFFLINE TO CA PMO
PMO362I NO VOLUMES CURRENTLY OFFLINE TO CA PMO
PMO363I VOLUME vvvvvv CURRENTLY OFFLINE TO CA PMO
