After you exclude a LNKLST library with the F PMO,EXCLLNK command or the EXCLLNK parameter, you can instruct CA PMO to start managing the library again. For instance, you might want to undo an exclusion if CA PMO can save elapsed time by managing the library.
You undo an exclusion of LNKLST libraries with the following command:
F PMO {,INCLLNK=data set name}
{,INCLLNK=ALL}
This command has the following operands:
The CA PMO keyword.
You specify this operand as follows:
Tells CA PMO to start managing the specified data set again.
Tells CA PMO to start managing all excluded LNKLST libraries again.
After successfully executing this command, CA PMO responds:
PMO328I INCLLNK SUCCESSFUL FOR DSN=data set name LNKLST=linklistname
CA PMO continues to accumulate statistics for the specified library or libraries on the D4 monitor display. CA PMO does not reset the statistics obtained while a library was excluded from management.
If the specified library is already being managed by CA PMO, it responds:
PMO324I PMO IS NOT CURRENTLY EXCLUDING DSN=data set name
If you issue the command F PMO,INCLLNK=ALL, but CA PMO is already managing all LNKLST libraries, it responds:
PMO326I NO LNKLST LIBRARIES CURRENTLY EXCLUDED
If CA PMO cannot manage the library because you need to increase the value of the MLSIZE parameter, it responds:
PMO321I MLSIZE=0 - UNABLE TO INCLLNK DSN=data set name
If the library that you specify with this command is not in the LNKLST, CA PMO responds:
PMO322I PMO UNABLE TO INCLLNK DSN=data set name
If you receive message PMO322I, check the D4 PMOMON display for the correct names of LNKLST libraries.
Copyright © 2011 CA.
