The FDR command changes the status of the CA PMO/FDR interface.
Note: This command has no effect if the CA PMO/FDR interface has not been installed.
The FDR command has the following syntax:
F PMO,FDR=interface option
This command has the following operands:
The CA PMO keyword.
You specify this operand as follows:
Tells CA PMO to enable the CA PMO/FDR interface so that updates will be communicated to CA PMO.
Tells CA PMO to disable the CA PMO/FDR interface so that updates will not be communicated to CA PMO.
Copyright © 2011 CA.
