Previous Topic: XCFMEMBR ParameterNext Topic: XSYSCOMM Parameter
XSYS Parameter
This parameter is required if you use PMO/XSYS. It indicates the systems that are to receive information about directory updates. If you specify this parameter, PMO/XSYS is started automatically when CA PMO starts up.
Format
The XSYS parameter has the following syntax:
XSYS=cross-system option
where cross-system option has the following value:
system-ID1,system-ID2,...,system-IDn
PMO/XSYS passes information about directory entry updates to each system specified as a value to the XSYS parameter. Put blank spaces to the right of an SMF system-ID that is less than four characters long.
Default: None
Examples
XSYS=CPU1,CPU2,CPU3
XSYS=SA  ,SB  ,SC
Note:
