Previous Topic: SYSOUT ParameterNext Topic: USERCOST Parameter
TOPSECRT Parameter
Indicates whether CA PMO will coexist with eTrust CA Top Secret. For more information on compatibility among products, see the chapter "Compatibility with Other Products."
Format
The TOPSECRT parameter has the following syntax:
TOPSECRT=coexist option
where coexist option has one of following values:
NO
Indicates that CA PMO will not coexist with eTrust CA Top Secret. Specify this value if you do not use eTrust CA Top Secret.
Default: TOPSECRT=NO
YES
Indicates that CA PMO will co-exist with eTrust CA Top Secret.
Note: If you use both eTrust CA Top Secret and CA PDSMAN, do not specify TOPSECRT=YES. Doing this causes CA PMO to continually stop and restart itself, exhausting ECSA in the process. If you have both of these products, see the chapter "Compatibility with Other Products."
