Indicates where offline reports are sent. You can specify that offline reports are sent to a particular SYSOUT class, which spools them for a printing device. Alternatively, you can specify that offline reports be written to a particular data set.
The SYSOUT parameter has the following syntax:
SYSOUT=report destination
where report destination has one of following values:
A one-character SYSOUT class, which can be any letter from A to Z or an integer from 0 to 9.
Specifies that offline reports be written to a data set. You specify the actual data set name as a value to the RPTDSN parameter.
Default: SYSOUT=A
Copyright © 2011 CA.
