Previous Topic: OPERMSG ParameterNext Topic: REFDELAY Parameter
PANEXEC Parameter
Indicates whether CA PMO will coexist with CA Panexec. For more information on this topic, see the chapter "Compatibility with Other Products."
Format
The PANEXEC parameter has the following syntax:
PANEXEC=coexist option
where coexist option has one of following values:
NO
Indicates that CA PMO will not coexist with CA Panexec. Specify this value if you do not use CA Panexec.
Default: PANEXEC=NO
YES
Indicates that CA PMO will coexist with CA Panexec. Specify this value if you use CA Panexec. This ensures compatibility between the two products.
Note: If you use both CA Panexec and CA PDSMAN, do not specify PANEXEC=YES. If you do, CA PMO will continually stop and restart itself, exhausting ECSA in the process. If you have both of these products, see the chapter "Compatibility with Other Products."
CA PMO will not manage CA Panexec libraries if you specify PANEXEC=YES. If you have CA Panexec and specify PANEXEC=NO, you must exclude all CA Panexec libraries with the EXCLAUTO parameter.
