Previous Topic: NUMCANDS ParameterNext Topic: PANEXEC Parameter
OPERMSG Parameter
Determines whether CA PMO notifies the operator of updates before it refreshes the LLA. This parameter is valid only if you also specify the parameter LLA=AUTO.
Format
The OPERMSG parameter has the following syntax:
OPERMSG=LLA refresh option
where LLA refresh option has one of following values:
NO
CA PMO performs an LLA refresh without asking for operator permission. CA PMO waits to perform the refresh for the amount of time specified on the REFDELAY parameter. CA PMO displays messages PMO520 and PMO522 when this happens, and PMO/XSYS displays messages PMO750 and PMO752. Specify OPERMSG=NO if CA PMO is to selectively refresh LLA. CA PMO also displays message PMO518 and PMO/XSYS displays message PMO758 if you choose this option.
YES
CA PMO asks the operator whether it should perform an LLA refresh, and it performs the refresh only if the operator answers YES at the console. CA PMO displays messages PMO519 and PMO522 for the operator, and PMO/XSYS displays messages PMO759 and PMO752.
Default: OPERMSG=NO
