This parameter instructs CA PMO to install the Directory Entry (DE) Services exit during initialization. The DE Services exit is required when a PDSE-type library is present in the LNKLST concatenation or in a private library concatenation. When DESERV=YES is specified, CA PMO installs the DE Services exit and manages non-PDSE directory requests.
The DESERV parameter has the following syntax:
DESERV=option
where option is one of following values:
CA PMO installs the DE Services exit.
The DE Services exit is not installed.
Default: NO
Copyright © 2011 CA.
