The time interval for which PMO/XSYS reads from and writes to the control file.
The CYCLE parameter has the following syntax:
CYCLE=x
The CYCLE parameter requires the following value:
Time interval, in seconds, where 10 < = x = > 1. Consider changing the value only if you feel it is taking too long for updates to be migrated across systems.
Default: 10
Copyright © 2011 CA.
