Previous Topic: DESERV ParameterNext Topic: DFDSS Parameter
DESIZE Parameter
The size of library directory entries. For more information on this topic, see the chapter "Compatibility with Other Products."
Format
The DESIZE parameter has the following syntax:
DESIZE=directory entry size
where directory entry size has one of following values:
64
The usual size of directory entries. Specify this value if you do not have CA PDSMAN, CA Jobtrac, or CA Workload Automation SE. This will save 12 bytes of virtual storage for each member.
76
The maximum size of directory entries. Products such as CA PDSMAN, CA Jobtrac, and CA Workload Automation SE have libraries that require you to specify DESIZE=76, even if CA PMO is not managing these libraries. The size of each managed list and hash table entry increases by 12 bytes.
Default: DESIZE=76
