The monetary cost of one CPU second.
The CPUCOST parameter has the following syntax:
CPUCOST=monetary cost
The CPUCOST parameter requires the following value:
The monetary cost of one CPU second in whatever units you have set with the MONYSYM parameter. CA PMO uses this value to calculate the money that it saves by reducing CPU time. PMOMON shows the cost savings on the D5 display.
Note: Be sure the value you provide for CPUCOST is consistent with the monetary symbol that you specify as a value for the MONEYSYM parameter.
Default: None
Copyright © 2011 CA.
